Need help with rear brake pads.
Old Aug 26, 2014 | 03:14 PM
Tajohns34's Avatar
Default Need help with rear brake pads.
Just a quick question. How far should the piston on the rear caliper on a 2000 blazer be compressed? I tried doing my rear pads today but I couldn't get the piston compressed far enough. Should it be flush with the caliper?
Old Aug 26, 2014 | 05:25 PM
jmparker82's Avatar
jmparker82 is on a distinguished road
Yeah the piston should just go to being flush with the caliper. If the pads still don't fit then they may have gave you wrong pads or rotor.
Old Aug 26, 2014 | 07:07 PM
rexazz2's Avatar
cheap aluminum calipers on rear of my 05
ended up replacing both the last brake job because the pistons were to tight pushing back
the piston should be flush when compressed
Old Aug 27, 2014 | 04:56 AM
Tajohns34's Avatar
They weren't completely flush, but I couldn't get them to go in any further. I guess I just need a bigger c clamp.
Old Aug 28, 2014 | 02:19 PM
donny612's Avatar
donny612 is on a distinguished road
Had the same problem just recently. I was trying to do my brakes myself to save $$$. Bought pads/rotors and for whatever reason started with the rears first. Could not get the caliper piston pressed in far enough to get the caliper back on over the rotor. Not like I've never done this before. Did a full brake job on my old Explorer 2 or 3 years ago. Anyway, ended up taking it (put the old pads etc. back on.) to my son's shop and he determined that the cylinder in the caliper had some kind of build up preventing the compression of the piston back into the caliper. Had to replace the caliper. After that...no problem. Good luck!
Old Aug 29, 2014 | 04:49 AM
Tajohns34's Avatar
When I tried to tighten it all the way my c clamp actually broke in half. Maybe I need a new caliper, and I definitely need a new clamp.
Old Aug 29, 2014 | 05:03 AM
odat's Avatar
sometimes when compressing the caliper with a C clamp it helps to open the bleeder at the same time - relieves the back pressure - also use a old brake pad between the caliper and the clamp to keep the pressure on the caliper piston square
Old Aug 29, 2014 | 08:16 PM
Calipers should be replaced each time the brakes are done, (especially aluminum calipers). Brake fluid is hygroscopic, (it attracts moisture). When moisture enters the caliper, corrosion starts, and eventually the piston binds. When the piston binds, the pads drag on the rotor and wear out the pads and rotor prematurely. Cheaper in the long run to do the job right one time.
Old Aug 30, 2014 | 10:28 PM
rexazz2's Avatar
I use one of these to push back the piston
they are reasonably priced and if you can not easily turn the thumb screw you know you need a caliper
OEM/Disc brake pad spreader (25265) | Brake Tool | AutoZone.com
it works on most calipers
jeepattack89
77
Mar 30, 2013 12:54 PM
Maxboost25psi
27
Mar 4, 2013 05:26 PM
smokin
Oct 9, 2012 09:14 AM
Blaize70
Sep 3, 2007 07:52 PM
