need help trying to figure this out
Old Aug 28, 2011 | 09:51 PM
darknight's Avatar
darknight is on a distinguished road
Unhappy need help trying to figure this out
I cant seem to get my climate in my truck to blend... It's either too hot or too cold... And when I try to clear my windsheild with some warm air I can feel air blowing frm my ac vents and the vent down by my feet also... Damn it even blows when I have my climate controls off.... What can I or should I do to correct this???? Please help... I'm begging u guys please help me thanks!!!!!
Old Sep 2, 2011 | 05:47 PM
darknight's Avatar
Damn no one?
Old Sep 2, 2011 | 06:22 PM
Senshi09's Avatar
Senshi09 is on a distinguished road
blend door actuator switch is what id look at first.
Another member with more experience/knowledge in that area can probably confirm it. But from what you said, thats what i'd see the problem being. You say its either to hot or cold.. warm air is coming through at all times.. its coming from all vents... it really does sound like your blend door isn't working to me.
There might be a DIY in the tech article section for it.. if not im sure there has to be some sort of schematics on it here somewhere.
Last edited by Senshi09; Sep 2, 2011 at 06:27 PM. Reason: re-worded it so it didn't sound so mean
Old Sep 2, 2011 | 06:43 PM
pettyfog's Avatar
Ummm I think he has worse {or better, depending} problems.. probably not in heater itself. Doesnt seem to be able to control anything, right? Even the blower, or are you talking airflow while driving?
Guess I'm asking if you can control blower speed. If you can, then check for vacuum into the heater controls
If the blower doesnt work, either then check the IP fuse panel
Old Sep 2, 2011 | 08:07 PM
darknight's Avatar
Thanks senshi09.... @pettyfog my blower motor worked fine at all speeds... It's just a matter of me being able to control the temp... It's either too hot or too cold... And yes I can feel air blowing all the time while driving even with the air off... And lastly air seems to blow out of all vent t the same time... Ac vent, floor vent and window defroster all so....
chevyblazer9588
Aug 5, 2011 08:44 PM
Arby24
Jun 22, 2011 07:52 PM
PaulO2288
Nov 1, 2010 06:10 PM
chevfan2000
Jun 8, 2010 05:59 PM
Leo_P3547
Mar 28, 2010 11:28 PM
