Need Help with Vac line found not connected
Old Oct 23, 2013 | 06:51 PM
The image in post #6 is taken from the center of the engine looking at the left inner fender. The part on the right is the ABS unit, and the part on the left is the cruise control module. It's possible that the plastic nipple is broken off flush with the vacuum reservoir, in which case, you won't feel it.
This image show the orientation of the reservoir, (the arrow points to the front of the vehicle):
Here is another view, (the arrow points to the front of the vehicle):
Attached Thumbnails Need Help with Vac line found not connected-reservoiramplines_zps1a7c4744.gif   Need Help with Vac line found not connected-vcuumreservoir_zps80128f64.png
Old Oct 23, 2013 | 07:12 PM
HostileJava's Avatar
HostileJava is on a distinguished road
Thanks, I'll try again tomorrow.
Old Oct 24, 2013 | 11:18 AM
blackedoutv6's Avatar
blackedoutv6 is on a distinguished road
So on non 4wd Blazers, is one of the ports on the side of the check valve that has 2 nipples (lol) just capped off? Or does it go to something else?
Old Oct 24, 2013 | 04:50 PM
On 4WD there is an additional vacuum Tee with a line that runs down to the vacuum switch on the transfer case.
Old Feb 2, 2024 | 09:27 AM
C210M's Avatar
C210M is on a distinguished road
Would the nipple be located in the same location on my 2004 blazer?
Old Feb 2, 2024 | 09:53 AM
LesMyer's Avatar
AFAIK, Yes
Old Feb 2, 2024 | 11:43 AM
C210M's Avatar
I found the vacuum res but the nipple is broke off. How do I fix that?
Old Feb 2, 2024 | 02:29 PM
The nipple on the vacuum reservoirs is recessed. Have you confirmed this?
If the nipple is broken, I suppose you could epoxy in a plastic tube or try to replace the reservoir. I've attached the instructions for replacing the reservoir but it requires removing part of the braking system (also attached).
The part number for the reservoir looks to be 15720833
(https://www.gmpartsgiant.com/parts/g...tra2=&filter=())
The final solution is to find a vacuum reservoir that can be mounted somewhere else. The 1st gen Blazers had one that was attached to the inside of a fender or to the underside of the hood I think.
https://www.dormanproducts.com/p-17836-47076.aspx
BigEffingHammer
Mar 11, 2013 07:46 PM
ccross13126
Jan 20, 2012 10:07 AM
gpeebles
May 5, 2011 10:08 AM
speedfreak81
Feb 4, 2010 08:52 AM
va454ss
Feb 17, 2008 08:45 AM
