Need a little help
Old Oct 31, 2011 | 06:24 AM
mross45640's Avatar
mross45640 is on a distinguished road
Default Need a little help
My 99 blazer now that it is getting cold out only puts out heat part of the time it goes hot/cold/hot/cold any suggestions?been reading on here but only confusing me more thanks for the help
Old Oct 31, 2011 | 01:57 PM
warthogdriver's Avatar
sounds like your heater core is slightly plugged, or have air in the system and you need a coolant flush.
if it were air in there though you would hear a "running" water sound from passenger side.
Old Oct 31, 2011 | 02:01 PM
chris015's Avatar
Yea...check your coolant levels. If its still doing it, flush your heater core...remove the 2 lines going to it,stick a hose pipe on one end,let er rip!
Old Oct 31, 2011 | 07:44 PM
mross45640's Avatar
I actually found out something interesting on way home tonight.with the control turned to 82 barely any heat.turn it to 78 freezing cold.i flipped switch several times very rapidly and heat I'm thinking the blend door actuator is partially stripped.i can't hear anything behind dash when you flip the switch back and forth I will know more on Friday my day off so I can check it good thing it has heated seats till then lol
Old Oct 31, 2011 | 07:58 PM
blend door could be it...i dont have one on mine, but have seen several threads about it.
the devil is in the details.
Old Nov 1, 2011 | 05:16 AM
mross45640's Avatar
I flipped the temp control switch back and forth when I started truck this morning about 5 miles out of town had to turn heat off was baking me so really pointing toward under dash to me.i did check coolant this morning it was full and clean looking.i believe had dex cool in it because it is orange
Old Nov 5, 2011 | 05:22 AM
mross45640's Avatar
That's the problem the actuator the gear must be stripped
gojo83
Jan 19, 2010 01:40 AM
MyChevyBlazer
Tires and Wheels
Nov 22, 2009 05:39 PM
johnsonmopar
Oct 20, 2007 10:07 AM
Gimpy
Jun 11, 2006 02:55 AM
freeman
Sep 28, 2005 03:42 AM
