Need PSI info
If you go by the door jamb sticker, you'll get a softer ride, less fuel mileage, and the tires will wear out quicker. For the best fuel mileage and tire longevity, inflate them to 10% less than the maximum pressure listed on the sidewall of the tire. If it says 44psi, inflate it to 40psi, etc.
As Capn said. But you also have to factor in the pressure before you inflate. Whatever your personal inflation interval if you have a tire that is 10%below the others THAT tire should be given a 10% boost in pressure. That way all tires share closer pressures for the longest time. e.g Mine get 39,39,40,38. When I next check them I get 36,36,34,35
Fivspeed
41
07-22-2013 07:40 AM
94NDTA
03-10-2008 04:20 PM
93LT
01-16-2006 09:36 PM
