Need to remove the passenger side door panel
Old 06-28-2012, 01:53 PM
1996 Blazer Driver's Avatar
1996 Blazer Driver is on a distinguished road
Default Need to remove the passenger side door panel
Have to replace a broken side view mirror. . I found one clip directly under where the mirror is mounted. Also two screws under a cover where you pull the door shut. It appears that the door opener latch [pull to open door] has to be removed and the plastic around the door opener and lock. But cannot find the secret. I know once the necessary hardware is removed, the panel will come off by pulling upward. But I am having trouble with the clips, screws and hardware removal/ Any tips would be appreciated.
Paul
Old 06-28-2012, 02:57 PM
OK. I have the panel off. Everything fine except I cannot disconnect the wire [harness] from the mirror. Tried to squeeze and pull but no luck
Paul
Old 06-28-2012, 03:41 PM
Smile
Thanks. I got it
TheDevilsDaddy
10-12-2015 10:34 AM
luke825
11-25-2012 10:29 AM
kyle187
08-18-2009 12:27 PM
bp2935
02-02-2008 02:25 PM
Quick Reply: Need to remove the passenger side door panel
