Need some advice on 95 blazer,Please anyone!
Old Oct 26, 2010 | 02:06 PM
dinomotz19's Avatar
dinomotz19 is on a distinguished road
Question Need some advice on 95 blazer,Please anyone!
changed heatercore and now tranny is shifting all weird. it is shifting from first at about 5mph then out of second at 10mph. also noticed if i put it in 1st gear it is shifting out of first and into second...? is there any wires or things in the dash that could have got messed up when i took it off that had to do with shifting?? need major help? also had a misfire on cyl.4 changed plug,wires,cap and rotor..checked compression and motor is still mising and suggestions on what to check next..also the tccm box was making all kinds of weird noises when i would put it in gear.clicking noise does it effect the shifting or only with 4wheel drive?? please help!!!
Old Oct 26, 2010 | 08:39 PM
Sparky's Avatar
Sparky is an unknown quantity at this point
You probably disturbed the wiring harness to the ECM that is located behind the glovebox, or behind the passenger kick panel. Check all the cable plugs to see if they are connected good to the ECM.
94driven
Nov 14, 2009 12:43 PM
chester90
Oct 24, 2009 03:31 PM
rcravincase
Sep 13, 2009 07:58 PM
neogeo92
Apr 28, 2006 10:51 AM
Disturbed
Feb 15, 2005 10:32 PM
