need some help
Old Sep 19, 2009 | 06:12 PM
96blazerky's Avatar
96blazerky is on a distinguished road
Default need some help
ok i jus bought a 96 blazer from my boss. i work as a mechanic and my boss is the owner so we kno alot about cars but cant figure this one out. it was running but the spider assy was leaking so he had another employee put that in, after that no start and no fuel pressure. diagnosed it as the pump, he had that put in. we got good psi now but still no start. so i ended up buying it from him for a heck of a price since he was tired of dealing with it. i got ta checkin everything and found out timing was off. so i got it up to tdc and also lined up the distributor and i kno everything is lined up right i did it about 5 times. well i still cant get it to start. its weird bc it has fuel, spark and compression so i cant figure out y it wont start. any ideas on wut is going on? like i said it ran fine until they put the spider assy in and hasnt ran since. i also have removed upper intake and there are no leaks from the injectors so that was installed correctly
Old Sep 19, 2009 | 06:46 PM
danmiranda's Avatar
danmiranda is an unknown quantity at this point
What fuel pump is in there? Some aftermarket fuel pumps are total junk, and you may not be getting enough fuel to start.
Old Sep 19, 2009 | 08:58 PM
96blazerky's Avatar
its a delphi weve had good luck out of this brand and it is getting 63 lbs when u turn the key on
Old Sep 19, 2009 | 09:03 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
when you set the timing did you set it at the 6 cast into the bottom of the dist.? look at this...https://blazerforum.com/forum/tech-articles-diy-29/edi-engine-timing-24373/
Old Sep 19, 2009 | 09:18 PM
96blazerky's Avatar
yea we got factory service manuals at work so its dead on
Old Sep 20, 2009 | 06:42 AM
reelbroke2's Avatar
will it run on starting fluid?
Old Sep 21, 2009 | 07:40 PM
96blazerky's Avatar
okay i tinkered wit the blazer all day and got it started and drove it. it drove perfect. so i thought my problem was fixed. i took it around the block and came back ta work and parked it. when i went ta get in it ta go home it would just crank and crank. but when it cranks it will start to crank fine then it will just completely stop cranking like it lost battery connection. terminals good and tight tried a new battery but still the same. i dont kno if you all kno wut i mean by me sayin i think it is hydraulicing or not but that seems ta be wut it is doin. pretty much hydraulicing is when theres too much gas in the cylinders and the pistons cant compress fully. any ideas
Wyatt Abshire
Jul 12, 2012 08:27 AM
davidluzader
Mar 1, 2010 10:25 AM
rcravincase
Sep 13, 2009 07:58 PM
ZLover4Life
46
Dec 22, 2008 01:01 AM
scottyk
Mar 19, 2007 11:32 PM
