need some help
need some help
front diff not locking before and after installing a posi lok the t case is working was should only thing I can think of is that its something inside the front diff that is broke
the seals in the 4WD actuator are probably gone, very common problem expecially if you had a leaky battery becuase its located under the battery. pop the battery out and see if you have vaccum pressure in the actuator and make sure the rubber is ripped. & then and see if the cable is seized or not.. if everything looks fine, but there is no vaccum pressure its the switch on the side of the transfer case, cheap fix but a pain in the A$$. Other than that I could only think that maybe the cable isn't adjusted properly on the side of front diff.. when you took the diff out and removed the cable maybe now it needs re-adjusted.. also there is a shift fork in the front of that diff and if you put it in backwards it wont engage, & or that could be broken if you engaged the four wheel at a high speed.
hope this helps !
hope this helps !
davidluzader
03-01-2010 10:25 AM
rcravincase
09-13-2009 07:58 PM
ZLover4Life
46
12-22-2008 01:01 AM
scottyk
03-19-2007 11:32 PM
