Need some help... - Washer Fluid Pump
Old Apr 10, 2011 | 11:33 AM
mikeyg6754's Avatar
mikeyg6754 is on a distinguished road
Default Need some help... - Washer Fluid Pump
Well, I went to the parts store this morning to get a washer fluid pump for the front... Thought it would be an easy fix... Guess not, there is no voltage going to the front pump ... Does anyone have a wiring diagram that shows where the front connector goes to? I don't really want to rip everything apart without knowing where I'm going to check...
Thanks in advance...
BTW
Just bought it used so IDK how long it has been broken.
2001 Blazer
4.3 V6
Mike George
Old Apr 10, 2011 | 11:39 AM
rriddle3's Avatar
*Moved to '2nd Gen Tech'. Please read the section description before posting a thread in it. The 'New member' section is only for introducing yourself and your vehicle.*
Old Apr 10, 2011 | 01:38 PM
mikeyg6754's Avatar
sorry... thought I could only post in the new member area.
Old Apr 29, 2011 | 12:55 PM
4.3l trouble's Avatar
4.3l trouble is on a distinguished road
Default I have the same problem
have you checked for a short to ground?
Old Apr 29, 2011 | 07:41 PM
There are two pumps in the reservoir: front and rear. Make sure you're checking the right one.
Old Apr 30, 2011 | 07:39 AM
mikeyg6754's Avatar
I fixed it a little while ago... I just took out the whole reservoir and got to the connector for the front washer pump, made sure the connection was good and then it worked.
Old Apr 30, 2011 | 11:40 AM
Cool, thanks for posting back.
tjbmxrider
Apr 21, 2009 12:23 AM
carlo
Jan 1, 2007 03:03 PM
jboy76
Jun 7, 2006 09:25 PM
kaindragoon36
Mar 25, 2006 04:22 PM
fruccoman
Feb 15, 2006 07:08 PM
