Need some major help!!
When the 4HI button is pressed do you hear or feel anything? Put the transmision in park or neutral to do this.
If you hear or feel a clunk....technical term there....then the encoder motor is working.
What do you mean that the vacuum diaphram has been bypassed? Have you checked...better yet replaced the vacuum lines between the engine intake, to the reservior to the vacuum switch, to the diaphram? Especially check in the left corner of the engine compartment...that is where the vacuum lines rot out for some reason.
I put a pull cable on the front axle cable to lock it in and when i press it i dont hear anything but i took the encoder motor off and tryed engaging it and the motor wheel did not move but the buttons lit up 2hi and 2lo
santmire
05-28-2011 01:39 PM
