need some power window help please
ive got 97 blazer LS 4dr. all the windows work from drivers side control but wont work from any of the other controls? it was working the other day and the lock isnt on??
RE: need some power window help please
bump
i had the same problem when i first got my blazer. all i did was clean the connections in the lock switch. took 5 minutes. just be careful not to break any of the plastic clips... theyre fragile in the cold.
Sounds like you have a bad widow lock-out switch...
thanks guys im going to check it out today ill let u know if i fix it
cool i fixed it all i did was removed the cover and pushed the connector back in better. simple loose connection thanks guys
Jimmy Williams
02-16-2013 11:36 AM
davidluzader
03-01-2010 10:25 AM
chrisjanicki01
11-14-2009 05:45 PM
scottyk
03-19-2007 11:32 PM
