need spark plug wiring diagram NOW!! Backfiring real bad!!
Old 02-24-2011, 07:18 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Well, aside from wires being switched around, forgetting to plug in the connector on the distributor will also cause some issues.
Old 02-24-2011, 11:56 AM
This edit of the image that Captain posted above that I did a WHILE ago shows the trace layout on the cap:
If you have never seen a cap like this, then you haven't been working on any mid-95 through the middle 2000's Chevy trucks (whenever the coil per plug change took place). The V6 & V8 distributor caps are all pretty much like this. It simplifies the plug wire routing.
Old 02-24-2011, 02:04 PM
The cap is designed like that to reduce crossfire in the cap. If you follow the terminals, it follows the firing order 165432. Make sure you put a dab of silicone dielectric grease on each terminal, inside and out, of the cap. Don't waste your time and or money on aftermarket caps, stick with AC Delco.
Old 02-24-2011, 02:39 PM
LRV31's Avatar
LRV31 is on a distinguished road
If AC Delco caps are still made as they were years ago with the aluminum terminals then there are much better caps out there. Wells Gold, Accel & Summit Racing caps all have brass terminals are are higher quality then the AC Delco.
Old 02-24-2011, 03:18 PM
Yes, AC Delco caps use aluminum terminals.
I can't tell you how many aftermarket caps I've replaced with AC Delco ones on 4.3's with a crossfire problem. Could easily fill a trash barrel with them. Use silicone dielectric grease and make sure cam retard is within specs and they'll go 100K miles. Never seen any aftermarket cap go that long without a crossfire problem, it just doesn't happen.
4.3l trouble
04-07-2019 06:54 PM
Somedudeintacoma
10-21-2014 02:22 PM
futuredoc
06-28-2010 02:50 PM
gmoney30
03-31-2010 09:04 PM
boulonman
03-05-2007 05:10 AM
Quick Reply: need spark plug wiring diagram NOW!! Backfiring real bad!!
