Need Upper Control Arm Bolt
Old Aug 26, 2008 | 03:16 PM
LONGER's Avatar
LONGER is an unknown quantity at this point
Default Need Upper Control Arm Bolt
Trying to get this thing aligned finally, replaced the brand new duralasts ball joints with Moog and solved that issue. Now I have another issue, the drivers side front upper control arm bolt is fried, bolt is spinning inside the washer not allowing the shop to adjust it. Where can I get just the bolt, nut, and washers? I tried gmpartsdirect.com but dont see a listing just for the bolts.
96 4x4
Old Sep 1, 2008 | 04:18 PM
LONGER's Avatar
Default RE: Need Upper Control Arm Bolt
Anyone????
Old Sep 1, 2008 | 06:04 PM
Short of a dealership with the appropriate parts catalogs or just nabbing one out of a junkyard, I doubt you will find the exact bolt in the aftermarket.
Old Sep 1, 2008 | 07:47 PM
LONGER's Avatar
found it, i think
http://www.ingallseng.com/parts/35120.htm
Old Sep 1, 2008 | 07:59 PM
Hopefully that works for you. Looks like they just milled down a standard bolt though...
Old Sep 1, 2008 | 08:05 PM
LONGER's Avatar
I really just need the washers anyway, mineare rounded out and the bolt just spins. They seem to be a pretty reputable outfit, they make all kinds of stuff and I found them at many different import performance websites.
Thanks for all your help, this site is the best.
ryanleh
Sep 3, 2011 08:46 AM
cage47
Jun 11, 2010 12:17 PM
blazer37
Aug 22, 2009 11:37 AM
Marcin
Nov 11, 2006 10:03 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
