new to forum, blazer trouble
Old Jan 7, 2009 | 07:11 PM
Celinas95Blazer's Avatar
Celinas95Blazer is an unknown quantity at this point
Default new to forum, blazer trouble
sold it
Old Jan 7, 2009 | 07:54 PM
rriddle3's Avatar
Default RE: new to forum, blazer trouble
[sm=welcomesign.gif]to the Forum. Your starting problem symptoms lead me to suspect the ignition switch going bad. How many miles are on the truck? Also, if you would put the important vehicle information into your signature, it might help with future diagnosis.
Old Jan 7, 2009 | 08:01 PM
mrafindley's Avatar
mrafindley is an unknown quantity at this point
Ignition switch all the way for all of your problem power windows cruise and the stall and the hard to start 100 percent ignition switch... Welcome to the forums.... Now the switch we speak of is not where the key goes in it is attatched to the column under all the plastic. It is a quick cheap fix
Old Jan 7, 2009 | 08:03 PM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
On a side note, dont run it "very low on gas" less than 1/4 tank and you are shortening the life of your fuel pump. Back to the question though, Id agree with rriddle sounds like your ignition switch is on the way out.
Old Jan 8, 2009 | 12:34 AM
volfan4's Avatar
volfan4 is an unknown quantity at this point
Have your battery tested and your battery connections cleaned and inspected first. That ignition switch for a 95 blazer cost over $130 at Autozone. The starters on these blazer can be damaged by low voltage. I had a similar problem and thought it was my switch. I had replaced the starter after it tested bad and my problem was still there. Turns out aweak battery and bad cable damaged the starter. Problem is fixed now. Just telling you this before you pay for that switch. The battery and cable is cheaper.
Old Jan 9, 2009 | 10:13 AM
Thanks so much for everyone's advice.
Old Jan 9, 2009 | 10:15 AM
just testing my signature
Old Feb 12, 2009 | 03:55 PM
got a malibu now
nate.chesebro
Nov 2, 2011 02:15 PM
chevsublaze
Apr 21, 2011 06:49 PM
illinois99blazer
Nov 8, 2008 10:40 PM
Johnszy72
Nov 1, 2008 10:16 PM
mysons95
Oct 11, 2008 05:26 PM
