new fuel pump problem
Old Feb 7, 2012 | 07:33 PM
badcarma02's Avatar
badcarma02 is on a distinguished road
Default new fuel pump problem
I just bought a new fuel pump for my 98 Blazer 4 door 4X4 it has a metal tank and i checked with the dealership parts dept. for the correct part number by VIN before ordering and they said it needed the AC Delco # MU 1772 so taking advice form most everyone i ordered the AC Delco. It currently has a Airtex in it Part #E3953M which cross refrences to that part #. My problem is when attempting to install it wont seem to fit all the way in what do i need to do ? any help ? Thanks in advanced.
Old Feb 8, 2012 | 09:14 PM
TouringMike's Avatar
TouringMike is on a distinguished road
Did you compress the top into the bottom section?
It should compress by 2 to 3 inches.
The 4 doors have an 18 gallon tank.
If your cross reference and VIN specify the MU1772, it should work.
I looked at Rock Auto, they say the Mu1772 is not for an 18 gallon tank. (?????)
Maybe what you need is # MU1733: MODULE,F/TNK F/PMP(SENDER & PUMP) 4 DOOR; w/18 GAL TK(NE2); INCLS SEAL; w/o LOW LUBRICITY FUEL SYS SENDER(K55)
MY1772:MODULE,F/TNK F/PMP(SENDER & PUMP) 4 DOOR; CODE SFG, SFU; w/o 18 GAL TK(NE2)
Look at your old pump, and see if it has the codes SFG or SFU on it's top.
If not, your new 1772 pump is the wrong unit.
Old Feb 9, 2012 | 02:59 PM
badcarma02's Avatar
I got the problem figured out ,the new rubber seal was so tight it wouldn't let the pump set far enough down to put the metal C ring in place. So I took the tank to a mechanic friend and I am letting someone with experience do it. Thanks for your help.
BouncingRadical
14
Nov 27, 2015 12:30 AM
cide
Nov 7, 2009 01:26 PM
upblazer95
Mar 8, 2009 07:15 PM
Lckyctch
Dec 30, 2007 05:38 PM
mytruck2
Dec 13, 2006 04:50 PM
