New here
Old Sep 15, 2018 | 04:12 PM
Mike.308's Avatar
Oh, I've missed the prompt welcome So, hi there buddy!
Starter mount, as far as I know, is a part of transmission case bell housing. Separating the bell housing from an engine is a PITA, as some of the bolts are well hidden (9 in total, as some of the diagrams indicate 8). I would rather think of resizing the threads, making an inserts or welding the part that broke off.
If You like the Blazer and want to restore it, my advice - do not hesitate and make a 2" body lift. It gives pretty good access to lots of the spaces (like starter, plugs and so on, including bell housing bolts).
Old Sep 16, 2018 | 12:22 AM
Ktribb's Avatar
Ktribb is on a distinguished road
Thanks Mike, this turned into an engine replacement, I got a decent motor for free to swap into it, the starter bolts are on the block, that’s why I tried using the Danchuk plate, two inches would probably have given me the space I needed, it’s a zr2, I thought it already had a lift on it? I’m not sure if it’s suspension or body though.
Old Sep 16, 2018 | 03:02 AM
Mike.308's Avatar
I am not 100% sure. but I guess that ZR2 has a suspension lift not the body - RC says that their suspension lift will not give 2" for ZR2 as it already comes with a lift. The body lift extends the rubber cushions between the frame and a body for 2", so if Your cushions are shorter than that, then it's not a body lift.
Good luck with Your swap. While doing mine, I have realized that lifting the body is an easy way of separating the engine and a bell housing and I've left it lifted.
Pay attention to the transfer case cooling lines and the engine oil that are clamped to the oil pan.
Jason10476
Sep 27, 2021 10:27 PM
thomas80
Dec 6, 2013 08:59 PM
donniejo32
Mar 14, 2013 11:28 PM
vinnivanhood
Apr 1, 2011 06:23 AM
jonesjamesw
Mar 20, 2008 07:46 AM
