New here with a big problem
Old May 30, 2013 | 09:53 AM
newguy's Avatar
A little leak, needs to be corrected
Old May 30, 2013 | 11:02 AM
bottlefed79's Avatar
bottlefed79 is on a distinguished road
while u are there fixing your fuel leak pull your egr valve and clean it up
Old May 30, 2013 | 01:34 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Im going to say you have bad ingnition module,The heat up engine dies.They cool off and they will start till they just completely die.Also With the rain you might have a crack in the dis cap.
Old May 30, 2013 | 01:56 PM
jimspahr@msn.com's Avatar
Here is a site you should Bookmark for future ref. It is easyautodiagnostics.com and covers the 4.3L V6 with specific tests to perform....and good photo's, too. It lists the Ignition Control Module---ICM,both early and late models. Look for a post in this 2nd Gen. section by Blazing Chevy who's title said something like '2000 Blazer w/Vortec V6 runs rough when cold and then when warm smooths out'. His solution was the ICM was getting moisture in it making it run roough when cold, but went the engine warmed up the ICM, it dried out the Module and the engine ran smoothly when warm. The ICM is on the right of the ign. coil and attached to the coil and cost less than $50.00.
Zr2.1
Apr 27, 2013 12:32 AM
Moores12345
Dec 29, 2010 07:22 PM
butters
Sep 29, 2008 06:40 PM
2001blazer
Tires and Wheels
Mar 9, 2006 02:39 PM
sunpowered
Aug 17, 2005 11:30 PM
