New LCA Ball Joint Problem
Old Nov 2, 2015 | 01:09 AM
teamrojas's Avatar
teamrojas is on a distinguished road
Default New LCA Ball Joint Problem
I am replacing the lower control arm, ball joints, stabilizer bar bushings on my 1998 Blazer LT 4x4. Here is my dilemma. The pre installed ball joint stud on the control arm does not go through the steering knuckle far enough to access the hole for the cotter pin with the castle nut on it. I tried to tighten the castle nut but it would not budge. I noticed the stud from the ball joint and the hole on the steering knuckle are tapered.
Could I bore the hole on the steering knuckle with a uni bit ( step drill bit ) making the hole wider so I can access enough stud to insert cotter pin and tighten the castle nut.
Thanks for your help...
Old Nov 2, 2015 | 08:09 AM
Tajohns34's Avatar
Are you sure you have the right ball joint? If it doesn't fit in the hole it probably isn't the right one.
Old Nov 2, 2015 | 09:28 AM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
In your other post, you were concerned you didn't have the correct part. Did you ever resolve this issue?
josemateos
Feb 18, 2014 10:00 AM
porkfriedrice
Jul 22, 2013 03:41 PM
Guntheone
Dec 4, 2010 05:59 PM
timetoblaze
Apr 17, 2006 12:47 PM
00ZR2BLZRGUY
Suspension Tech
Jan 1, 2006 08:12 PM
