new member..fuel problem
Old Oct 2, 2005 | 04:28 PM
nine5blazer's Avatar
nine5blazer is an unknown quantity at this point
Default new member..fuel problem
i just recently bought a 1995 blazer and its been throwing a code since i got it..the code was checked with e Tech2 scanner(dealer scanner) and it says the Fuel Pump Relay is what the code says..will this keep my truck from not starting sometimes and starting then turning off shortly? any help would be greatly appreciated..
Old Oct 3, 2005 | 02:03 PM
Hanr3's Avatar
Default RE: new member..fuel problem
Yes. The relay is less then $10. If you see black stuff oozing from the bottom of the relay you will need to replace it, plus you will need to clean the contacts in teh wiring harness. PB Blaster works good on teh contact, although you will still need to scrape the black ooze off.
Old Oct 6, 2005 | 05:31 PM
maldo's Avatar
maldo is an unknown quantity at this point
where is the fuel pump relay ?
thx Jim
Old Oct 7, 2005 | 03:26 AM
Hanr3's Avatar
Where is the fuel pump relay?
That would depend on the year of your truck. On my '87 it is located on the drivers side inner fender well in the engine compartment.
I hear in the newer body styles it is located in the glove box, or rather behind an acess panel in the glove box. I personally have not looked for it in there yet.
1994BlazerS10
Dec 28, 2009 01:59 AM
CB160
Dec 1, 2009 09:51 AM
Bathmite
Apr 10, 2008 01:40 PM
