New Radiator and Thermostat...running cool
Old Oct 12, 2013 | 09:59 PM
Cassera's Avatar
Cassera is on a distinguished road
Default New Radiator and Thermostat...running cool
I just replaced the radiator and thermostat on my 96 blazer. It used to run around 200 degrees with temperature fluctuating and heat was a hit or miss whenever I turned it on, but now it's running at about 155 degrees and it pretty much does not fluctuate. heat is constant but not very hot (as expected with a running temp of 160). I asked for a regular thermostat, I cant see why I would get a 160 degree thermostat (the box of the thermostat was not labeled with any info). Is there any other reasons that my car is running cool besides me getting and installing a 160 thermostat?
Old Oct 13, 2013 | 10:50 AM
rriddle3's Avatar
Replace that thermostat with the correct 195 degree one and see how the temperature does.
Old Oct 13, 2013 | 11:01 AM
gitch93's Avatar
gitch93 is on a distinguished road
u need the 195 degree thermostat I found that out when I installed the 160 it didt let the engine warm up enough to give u proper heat in the cab
Old Oct 13, 2013 | 01:24 PM
Cassera's Avatar
I bet I cant replace the thermostat without re draining and filling the system huh? Or am I wrong?
Old Oct 14, 2013 | 12:49 PM
bassson's Avatar
bassson is on a distinguished road
you will need to drain about 1/3 of the system, just drain the rad, disconnect the upper and drain that aswell
ohsofly
Sep 7, 2010 02:55 PM
Jonboy
Jun 4, 2010 11:25 PM
bigdaddykane93
Jan 4, 2010 12:03 PM
PaulO2288
Aug 26, 2009 03:04 PM
Steeltoe623
May 20, 2009 08:14 AM
