new vacuum lines, burning smell?
Old Jan 26, 2014 | 06:58 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
Default new vacuum lines, burning smell?
i just got a few vacuum lines replaced. i have no clue where they go to, i just told my mechanic that there were a few cracking over the brake booster ( drivers side right near brake fluid reservoir). he replaced as many as he saw cracked (idk how much the bill didnt come in) i noticed a burning smell right near the fuse box and brake fluid rservoir (in between that general area where i noticed new vacuum lines)
i did also notice a screw in the end of one of the T's of vacuum lines making it and L instead of a T if that makes sense.
can anyone shed light on this problem?
Old Jan 26, 2014 | 07:05 PM
He probably gave up looking for the vacuum reservoir in the driver fender and plugged the line. Take a few pics, from different angles, and post them.
Old Jan 26, 2014 | 07:23 PM
er0ck273's Avatar
gonna try doing that now, hopefully i get enough light off of the flash lol...stay tuned
and do you think that would be causing a burning smell? its only right there (the smell)
Old Jan 26, 2014 | 07:46 PM
er0ck273's Avatar
More are on the way.. it wont let me do more than 2 at a time
Attached Thumbnails new vacuum lines, burning smell?-20140126_202805.jpg   new vacuum lines, burning smell?-20140126_202800.jpg
Old Jan 26, 2014 | 07:49 PM
er0ck273's Avatar
last 4. if you need better views let me know
Attached Thumbnails new vacuum lines, burning smell?-20140126_202629.jpg   new vacuum lines, burning smell?-20140126_202639.jpg   new vacuum lines, burning smell?-20140126_202646.jpg   new vacuum lines, burning smell?-20140126_202658.jpg
Old Jan 26, 2014 | 08:15 PM
The black port on the Tee/check valve goes to manifold vacuum, near the PCV valve. Must have vacuum with the engine running.
The white port on the Tee/check valve with the screw, goes to the transfer case vacuum switch or the electric switch (if equipped) on the firewall.
The other white port goes to another Tee:
One side goes to a black plastic hard line for the HVAC system. It appears to be correct.
The other side of the Tee goes a smaller vacuum line that goes to the vacuum reservoir in the left fender. The nipple is between the firewall and the ABS unit, tough to see/find. Gotta use the "eyes" in your fingers to find it.
Old Jan 26, 2014 | 08:20 PM
er0ck273's Avatar
you say the port with the screw goes to the transfer case, would 4wd be affected? because thats the first thing i checked and it switched to auto 4wd fine
and this also might be a silly question. but new vacuum lines dont need to be broken in causing a burning smell would it?
Old Jan 26, 2014 | 08:47 PM
er0ck273's Avatar
and the hvac line has to be right, with the old line it wouldnt change all the time from floor to front vents, etc. it works correctly now and very quickly when changing positions of heat
Old Jan 26, 2014 | 09:08 PM
Jamaroon's Avatar
The line with the screw is supposed to go to the canister in the fender.
As for the burning smell, check to make sure he didn't put a new line that's too close or resting on the exhaust.
Old Jan 26, 2014 | 09:26 PM
er0ck273's Avatar
not having that line in the canister in the fender, would that do any harm? to anything? because i havent received a bill yet and wont pay til everythings done correctly
