New water pump, new thermostat NO HEAT!!
Old Nov 1, 2007 | 10:37 AM
yazan84's Avatar
yazan84 is an unknown quantity at this point
Default New water pump, new thermostat NO HEAT!!
I've recently got a new water pump installed on my 1999 4x4 blazer so as thethermostat, though I still get no heat at all!
what should I do? It's going to be freezing next week!
Old Nov 1, 2007 | 10:43 AM
rriddle3's Avatar
Default RE: New water pump, new thermostat NO HEAT!!
Did you have the coolant system flushed and refilled? When you run the heater, does the fan operation sound normal? Are there any unusual noises from the lower right side of the dashboard area? Is there a wet area in the passenger floorboard?
Old Nov 1, 2007 | 11:23 AM
Chevy Lover's Avatar
Flush the heater core and make sure that the radiator is full after the thermostat is open.
Old Nov 11, 2007 | 11:40 PM
yazan84's Avatar
Flushed and cleaned my coolant system today and the heathoses are getting hot but I'm still not getting any heat! My mechanic told my that the heater core could be clogged and/or the temperature **** 'In car thermostat" is not working. Hew also doubted that the heater core was bad!!Any other ideas?
Old Nov 12, 2007 | 12:34 AM
thegr81's Avatar
Mine was doing that till I figuired out how to get it to work and I know there is something wrong with mine. Before I start the truck I have all the controls off and ready for heat. I start my truck then turn on the heat and it works, as soon as I move my temp **** over to cooler just to have a nice climate it starts blowing cold. If I repeat what I did before it works fine. Just a suggestion for rigging it I guess, otherwise it may just be the switch.
Old Nov 12, 2007 | 01:10 AM
If both of you're heater hoses are the same temperature (hot), then it's a control or heat door problem. If there is a difference in temperature between the 2 heater hoses, then the heater core is at least partially plugged.
Old Nov 13, 2007 | 12:09 AM
yazan84's Avatar
problem fixed! heater core was clogged thanks guys
Old Nov 13, 2007 | 12:46 AM
Sweet!
craig1319
23
Jul 6, 2018 11:26 PM
BouncingRadical
14
Nov 27, 2015 12:30 AM
Kaffeene
Mar 15, 2013 10:23 PM
warthogdriver
Sep 29, 2010 10:14 PM
mcaanda
Dec 15, 2009 08:31 PM
