New waterpump, slight coolant leak and running hot .WTF?
Old Jun 22, 2023 | 05:57 PM
C.Hall's Avatar
C.Hall is on a distinguished road
Default New waterpump, slight coolant leak and running hot .WTF?
So last Saturday I replaced the waterpump on my blazer. Everything seems to go fine and I fill her up with coolant, I'm still getting a very small leak and my truck runs hot,not quite overheating over the 210 mark, between 210 and redline. I also smell the coolant but cannot seem to locate a leak. Any suggestions or a checklist of things to check/double check besides obvious things?( hoses,clamps...)
Old Jun 22, 2023 | 09:57 PM
rockp2's Avatar
What was the reason you changed the water pump? Was it bad or was it for the same symptoms you're currently experiencing? Two common things on this truck are a leak at the rear driver's side of the intake manifold. It can spit onto the exhaust manifold and dries before it can leak onto the ground. It can be difficult to see without specifically looking at that spot. The other is the heater core, you may feel dampness on the passenger side carpet. Those are just two possibilities to check.
tate456
Jun 23, 2013 11:35 PM
phatso_99blaz
May 5, 2013 10:01 PM
blazerbagpipes
Oct 16, 2012 09:37 AM
jsweed76
Aug 28, 2008 04:22 PM
la~man
Engine & Internal
May 16, 2006 10:40 PM
