New Yellow Top battery!!
Old Mar 12, 2008 | 09:18 AM
lionel2's Avatar
lionel2 is an unknown quantity at this point
Default RE: New Yellow Top battery!!
I don't wanna have to take out my battery because I have fuses attached to my battery and I dont wanna mess up my electronics, rather have a professional do it. But the problem is if I went to my battery shop they only have the 34/78 in stock and no 25/75 sizes in stock. Now if I said i wanted a new battery they would try to put in a 34/78 size and I dont think it will fit, then they have to put in my old one back, then order a 25/75 size then all of that will be a waste of time. Now if someone with a similar blazer has a 34/78 size under the hood then maybe I would know it will fit for sure, then i can go there one time only and get it swapped with a 34/78 size battery inside of all that other test fitting and removing and replacing the old battery. thanks.
Old Mar 12, 2008 | 08:21 PM
972DRBLAZER's Avatar
972DRBLAZER is an unknown quantity at this point
had my battery tray out, figured i would go ahead and measure it for you. at the narrow points; 6 3/4", 10 1/2". the tray does get wider at points, but this would be the size of thelargest battery that could fit in there. you could double check this by running a tape on yours. you should be able to measure your tray with out removeing your battery (it will be tight, but can be done). i hope this helps you. good luck with your voltage problems, i have my own that i cant seem to tackle.
Old Mar 12, 2008 | 08:47 PM
lionel2's Avatar
Yeah, I measured my tray. It will fit barely. I mean by less than an inch. Thanks for all the help. Well, when i get that alternator replaced and my current battery has enough juice in it, I will keep it til it dies, then get that 34/78 yellow top. thanks again.
Old Mar 13, 2008 | 09:19 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
It will fit , I have one in my 01 ZR2 but it's a red top ..
Zed
Old Mar 13, 2008 | 01:10 PM
lionel2's Avatar
Thank you for checking. Yeah, but wondering about the height and if hood will close, I guess if you are good I will be good. Thanks again.
Old Mar 13, 2008 | 03:39 PM
If you are still questioning this, consult Optima's website...
Optima Battery Dimensions
You should have no problems with your hood.
Old Mar 13, 2008 | 05:02 PM
lionel2's Avatar
Yeah, I went to the site this morning and wrote it down, the height, looks good as far as height, width, and length. Looks like the 34/78 will be my next battery. thanks.
Old Mar 13, 2008 | 05:36 PM
Zed's Avatar
Zed
@lionel2 , Proof , just for you
Old Mar 13, 2008 | 06:26 PM
lionel2's Avatar
thanks for the proof. Thanks for all the help guys.
Blade_24k
Jan 12, 2014 07:40 PM
jake kick
Apr 27, 2013 01:25 PM
ChromeJerome
Oct 7, 2012 11:46 AM
NVANZEE
Dec 26, 2008 04:49 PM
90blazinchevy
Oct 5, 2007 01:52 PM
