Newbie first post- where can I find RHD ignition switch?
Old Jan 11, 2019 | 03:31 PM
Richard Bell's Avatar
Richard Bell is on a distinguished road
Default Newbie first post- where can I find RHD ignition switch?
Hi all, new member from down under here.
I have a 2000 rhd blazer looking for an ignition lock barrel I have found that they are like hens teeth any advice or help would be greatly appreciated thanks
Old Jan 12, 2019 | 04:21 AM
Do you need the whole lock or just the key insert?
Need to find out what the difference is between the RHD and LHD steering columns. Might be that they are the same.
can you post a pic of what exactly you need?
Old Jan 12, 2019 | 04:15 PM
This is what im after except the bit that goes into the switch is in the middle and i need one that is off to the side. Just so im being clear my vechile is rhd,auto and the shifter is on the floor not on the column if that makes a difference.
Old Jan 12, 2019 | 04:27 PM
Mike.308's Avatar
I'm browsing a Rock Auto website just advised here. Probably You may get the part at a decent price:
https://www.rockauto.com/en/catalog/...cylinder,10041
Old Jan 12, 2019 | 06:17 PM
Welcome!
When looking for parts, I'll sometimes check the part numbers to see if they are the same or not. The US GM parts web sites are normally pretty good for that. You might find that the RHD and LHD lock cylinders parts are the same.
Old Jan 13, 2019 | 04:24 AM
same thought as Mike.308
Small parts should ship at reasonable prices.
Old Jan 14, 2019 | 05:54 AM
BooTs's Avatar
BooTs is on a distinguished road
Hi, Have you tried Bunce Motor Company Ltd in Auckland, NZ ? Good luck. BooTs
Old Jan 26, 2019 | 04:58 AM
Welcome!
no they are different as I have described
Old Jan 26, 2019 | 09:57 AM
go chevy's Avatar
Welcome too the Blazer Forum You found the right place for help and then some...
Old Jan 28, 2019 | 06:33 AM
I'd try looking into rockauto and compare to the same year of GM's different models.
Try looking for U.S. or Canada built cars. Once you figure out which cars used the same steering locks you may be able to broaden the search in the U.K. to find a spare or pick one in a scrap-yard.
rstrosky
Jan 3, 2015 08:20 AM
Dobe Rottie Gang
Aug 29, 2013 05:14 AM
Jonas
Sep 25, 2012 06:47 PM
duckland23
Aug 3, 2012 09:36 AM
96awd
Aug 31, 2011 06:44 PM
