Newbie from Maryland, 1997 problems
Old Sep 18, 2010 | 03:11 PM
ragamuffin's Avatar
ragamuffin is on a distinguished road
Default Newbie from Maryland, 1997 problems
Howdy, all. Glad to have found this forum. Took a while of searching, need to change my spark plugs and have never done it on this vehicle. This is my temp ride till I can get another car, but it won't start, and I gotta work on Monday! Wish me luck, going to go search now for a diagram, can't locate the plugs yet, rarely even look under the hood!
Seriously, this looks like a great forum. Thanks.
Old Sep 18, 2010 | 03:33 PM
rriddle3's Avatar
Well, if you just follow the spark plug wires, they pretty much lead directly to the plugs.
Seriously, push the flaps on the inside of the wheel wells inward and you can see the plugs without any trouble. The #3 plug (middle driver's side) can be a devil to get to, but use the 'search' function for '#3 plug', etc and you'll find plenty of info on methods to get to it.
Old Sep 18, 2010 | 03:38 PM
ragamuffin's Avatar
Ok. Thank you for that. I appreciate it-I wasn't sure if this was going to be a go-through-the-wheel-well type repair or what. I'm only experienced at working on my Chrysler, but should have figured, as everything was hard to reach on that as well. At least this vehicle is 'taller', maybe easier to get underneath! Thanks a bunch.
Rags
Old Sep 19, 2010 | 12:33 PM
step66's Avatar
Hey! Yes the #3 plug can be a chore as the steering column is in the way.
Here is how I do it: loosen the plug with a normal plug socket until you no longer have room to get the rachet off,then continue to loosen with a 5/8 wrench,then use your fingers. The simplest way to easily acces the plugs is with the front wheels off and get to them behind the inner fender splash guards!
Old Sep 20, 2010 | 12:05 AM
4x4blazerguy's Avatar
Getting to the plugs is great but you said it wouldn't start. Does it have proper fuel pressure (60 PSI)? I would think that you need to figure out why it won't start before you change spark plugs.
TFisher
Oct 11, 2009 04:34 PM
86Blazer4x4
Feb 24, 2009 11:38 PM
nj4x4blaze
Shows & Clubs
Oct 13, 2008 06:28 AM
jagblazer01
Shows & Clubs
65
Jan 25, 2008 08:28 PM
XBlazer01
Shows & Clubs
Mar 6, 2006 11:14 AM
