Newbie question: Wheel bearings
I have a '01 Chevrolet 2WD Blazer.
I need to have the wheel bearing(s) changed. Local mechanic that I always go to says "both" are very bad, and wants to charge me $800 to do them both, which might be fair in business terms, but I looked at some YouTube videos and the job is simple enough. I am going to buy the parts from 1AAuto.com for less than $100.
Here's the thing: I don't know anything about these parts. I have four wheels, mechanic said "Both of them are bad." Does that mean there are only two (I'm assuming the two front wheels)? Did he mean 'both' the front and back wheel on that side (when I take a right, the loud humming stops, so it's the passenger side that I thought was the problem). Did he mean both sides were bad?
It seems 1AAuto.com will sell these parts in pairs for a reduced price, the front and rear assemblies look completely different. Would the rear wheel bearings make the telltale loud hum?
From my experience:
right turn and noise stops would indicate that left side is bad as the load goes to the outside wheel in a turn.
Usually a mech will want to replace both bearings on the same axle; both fronts or both rear.
Bad front or rear bearings could make the telltale loud hum.
To find out which: jack-up front of Blazer and turn each front wheel by hand and listen. May require removal of tire/wheel and brake caliper depending upon just how bad the bearing is in order to hear.
If not front, then either assume rear or jack-up rear and try the samething.
Good luck.
Good luck.
When you turn, the load does go on the outside side. So a right turn puts all the load on driver's side. Since the hum goes away, it's assumed the bad bearings are on the passenger since the load is reduced.
I'm guessing he meant both front tires then, but I'll test all four as you suggested. Thanks!
Agreed, don't buy the cheap bearings unless you are planning on selling the car... 2 for less than $100 qualifies as cheap. The lower quality bearings are not designed to last and I've seen them with stamped ABS reluctors instead of solid.
I suppose I can afford $300 instead of $99 if Moogs is really as durable as you guys suggest. I'd still be saving $500.
Wonder why the 2wd front bearing/hub assemblies are more than the fronts for 4wd Blazers?
I purchased Timken hub/bearings for my '02 4wd which were about $100 each from Rock Auto. In fact I orderd them early, early on Friday morning and they arrived the next day!....and I did not pay for fast shipping.
Advance Auto Parts now has a promo on front Moog Hub Bearings and the 2WD are $155.99 each and 4WD are $140.99 each. The brand is not the issue in this instance. Yes, any 4WD parts is generally more expensive.
I checked RockAuto prices on 2wd and 4wd bearings, same brands for each and once again, the 2wd on more than the 4wd bearings.
Just odd to me as like jim stated above, 4wd parts are usually more costly.
Anyways I agree with staying away from the cheap bearings....just not worth having to do this job again in a short time.
