No bloody vacuum switch
Old Sep 30, 2018 | 02:28 PM
Westy's Avatar
Westy is on a distinguished road
Default No bloody vacuum switch
I spent about 2 hrs trying to find the vacuum switch on the transfer box. Just could not find it. Then found a thread on hear that said if you have a 4 button 4WD selector, then you don’t have one!
*****! I have bought one now.
could anyone explain how the system works please?
I have replaced the vacuum pipes going to and from the switch on the bulkhead. The vacuum actuator under the battery works. But the cable coming out seems to be seized.
sorry I am asking so many questions and thanks for everyone help.
cheers
westy
Old Sep 30, 2018 | 03:02 PM
Mike.308's Avatar
From my perspective, I consider the "vacuum" as a physical medium. Pretty much alike as pneumatics, except, the pressure is a "negative"[1] one. Some car systems have the air compressor for actuating this or that, some less-sophisticated ones like our Blazers works on a "vacuum". The vacuum suction derivatives from a running engine operation. It constantly consumes (sucks) the air through an air intake, so that phenomenon could be used as a control medium[2]. Opening/closing valves or pushing/pulling actuators eliminates use of expensive, prone to damage, electronic equivalents, yet providing a necessary amount of force.
Dig through the forum for a diagram sketch of the vacuum lines. That should give You more understanding of the system.
P.S. Do not worry of asking the questions. That feeds the dinosaurs daily driving blazers - like us/me. I'll be glad to help. I've been helped, so I consider it my duty to help others.
[1] Well, according to physics it can't be negative, but below atmosphere pressure. "Negative" just states a "reverse flow".
[2] I wonder how about the supercharged engines
Old Oct 2, 2018 | 03:30 AM
We may need to know the exact year and model and engine/transmission/transfercase setup to help.
Old Oct 2, 2018 | 04:03 AM
Here is a thread I started in which I listed the size and lengths of hoses I used when I replaced all of mine. In it I included a pretty useful diagram of the connections.
https://blazerforum.com/forum/2nd-ge...replace-95425/
Only read this part if you are really interested in the nitty gritty of the system. LOL
As for how vacuum actuator works, the most technical view would be that what does the work of moving the actuator is the atmosphere that pushes against the side of the diaphragm opposite the side that is connected to the source of vacuum. For this to work, there will be valves in the in the control mechanism that will control to what one side of the diaphragm is connected; vacuum or atmosphere. There will often also be a return spring to bring the diaphragm back to the position opposite the one to which it goes when the vacuum is applied so that when vented, the actuator returns to its original position.
The vacuum reservoir is there for when the engine vacuum is not very low because the engine is under load and the the pressure difference between the intake manifold and atmosphere is reduced. Since no system is perfectly sealed, a constant "supply" of vacuum is needed.
Old Oct 2, 2018 | 02:29 PM
Westy's Avatar
It’s a 2000 4.3 LT right hand drive, and I have the 4 button set up.
thanks for all of your help guys
man0steel
18
Aug 14, 2019 02:47 PM
frustrated jimmy
Dec 18, 2017 04:59 PM
SmileMore79
15
Jul 13, 2017 02:01 PM
dlundblad
Jul 4, 2017 11:59 AM
stephani555
Oct 31, 2010 08:39 AM
