no brake fluid to rear calipers
Old Mar 1, 2012 | 03:50 PM
madblazerowner's Avatar
madblazerowner is on a distinguished road
Default no brake fluid to rear calipers
Got a 2000 4x4 just replaced everything in the rear rotors pads and calipers went to bleed them and have no fluid to back but when I pulled off other calipers fluid ran everywhere is there to much air in the line
Old Mar 1, 2012 | 03:55 PM
Had burnt brake fluid as wel......l maybe lines clogged?????but can pump brakes till I'm blue in the leg still no fluid or air .......no leaks anywhere either
Old Mar 2, 2012 | 07:45 AM
spittybays
Guest
Posts: n/a
Just an idea. Take the bleeder valve completly out and see if it came from the factory with some crap in it.
Old Mar 2, 2012 | 09:52 AM
pettyfog's Avatar
This is a classic example WHY mods get pissed off when people double post their problems!
https://blazerforum.com/forum/2nd-ge...s-68518/page2/
Old Mar 2, 2012 | 03:00 PM
okiedoak20's Avatar
i had very similar situation, swapped out a rear that had everything already on the rear, went to bleed the rear calipers and they would not bleed, found the bleeder valve was messed up, so what i did was just replace both calipers, a little over board, but good excuse for new parts..
Old Mar 2, 2012 | 04:13 PM
Just replaced pads rotors and calipers went to bleed and no fluid had fluid with the other calipers so frustarted plus its got ABS so unfortunately with my new work schedule it might be heading to the dealer none of the local brake shops want anything to do with it
Maxboost25psi
27
Mar 4, 2013 05:26 PM
Lippyp
Feb 6, 2013 12:15 PM
spatula6554
Apr 10, 2012 02:17 PM
duvall45
Tires and Wheels
14
Jul 17, 2011 12:32 PM
tick
Mar 13, 2011 10:40 AM
