no brake lights
Old Dec 27, 2008 | 07:22 AM
kerbear1028's Avatar
kerbear1028 is an unknown quantity at this point
Default no brake lights
Hello everybody. I drive a 95 blazer 4dr 4x4, only 106000 miles. I just found out that my brake lights are not working at all. All three are out. rear lights ,flashers turn signals work. all fuses are fine. do I need to replace the switch that is down by the brake pedal?
I haven't tried replacing the bulbs to see if that helps yet. and just out of curiosity, I wonder if there is any chance that this could be related to my cigarette lighter not working. thanks in advance, I'm stumped
Old Dec 27, 2008 | 02:48 PM
cr8390's Avatar
cr8390 is an unknown quantity at this point
Default RE: no brake lights
i would say check fuses again check the fuse box in your car and under the hood. The check all grounds, it sounds like it could be a groudning issue
Old Dec 27, 2008 | 03:21 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Your Blazer doesn't have a fuse box under the hood, they added that fuse box in the 1998 model year. If your hazard lights are working that pretty much eliminates a bad fuse anyway, because the stop/haz fuse provides the battery positive voltage to the stoplamps AND hazard lamps. The bulbs use the same filiment for stop/hazard lamp illumination as well, so that would also eliminate faulty bulbs. As far as a bad ground, I'm pretty sure that all the rear lamps use the same ground circuit as well, so that should not be the culprit either. Your stoplamp switch is probably bad or the turn signal switch contacts are worn (the electrical contacs for the stoplamps inside the multi-function switch). You should get a fused jumper wire and disconnect the stoplamp switch (on your brake pedal mount) install the jumper wire acrross the terminals in the stoplamp switch that are connected to the white and orange wires. If your stoplamps come on with the wire installed the stoplamp switch is bad (open). If not you need to make sure there is battery positive voltage on that orange wire, and if there is, you have an open between the stoplamp switch and the turn signal switch, a bad turn signal switch or an open between the turn signal switch and the rear bulbs.
Old Dec 28, 2008 | 12:26 AM
cr8390's Avatar
ah lol see how much i know guess im just going by my blazer. But i would take advise from lastcoupe lol and thanks for correcting me last coupe was trying to point on some common problems that i have had and that could be wrong, but then again this isnt my veichle so, but yea thanks again
Old Dec 28, 2008 | 08:20 PM
SockJock's Avatar
SockJock is an unknown quantity at this point
Mine had the same problem.(1995 Blazer 4wd 4dr.)It was the wiring to the brake switch at the pedal. I don't know how long I had been driving around like that, but a nice older couple stopped me to bring it to my attention when I was headed to the grocery store. The wires had broken off at the plug itself. I ended up putting some generic female plug ends on each wire and trying different combos till I got the lights working again.
My problem is that I must have gotten 2 of the 4 wires wrong because now my ABS doesn't work. If someone knows what color wire goes to what I'd be very appreciative.
I forgot to add that I tried comparing the wiring to my 97 Blazer's wiring and they have different colored wiring to the brake switch.
edavison
Dec 20, 2010 09:55 PM
step66
Oct 14, 2010 04:52 PM
SCBlazer96
Apr 16, 2010 08:39 PM
dashyman
Jan 12, 2007 11:28 AM
rryker
Apr 25, 2006 04:14 PM
