No Fuel
Old Oct 24, 2009 | 06:26 PM
jmrosko's Avatar
jmrosko is on a distinguished road
Angry No Fuel
I have a 2000 Chevy Blazer. The vehicle started this about 2 months ago. When I turn the ignitition key to the normal starting point you will normally hear the fuel pump running. Well mine occasionally with not run and intern the blazer will not start. I have pulled the fuel tank down and there is no electric going to the fuel pump even when the ignition key is turned to run position.
I have heard this is a common problem!!! Note the blazer has 103,000 miles.
Any help would be appreciated.
Old Oct 24, 2009 | 07:09 PM
I will assume that you have checked and/or replaced the fuse and the relay.
When the truck does not start, have you noticed the 'security' light being illuminated on the dash? If so, the ignition switch is highly suspect.
Old Oct 25, 2009 | 05:06 PM
jmrosko's Avatar
when would the sucurity light be on?
95jblaze
Aug 27, 2011 03:46 PM
cide
Nov 7, 2009 01:26 PM
mytruck2
Dec 13, 2006 04:50 PM
Nations81
Aug 18, 2006 03:03 PM
jlinder
Aug 21, 2005 11:08 AM
