no heat
Old Jul 21, 2007 | 07:15 PM
greenblaze's Avatar
greenblaze is an unknown quantity at this point
Default no heat
I have a 98 blazer and the blower motor stopped working . How can I fix this? What should I test?
Old Jul 21, 2007 | 07:49 PM
BigGreenMonster's Avatar
BigGreenMonster is an unknown quantity at this point
Default RE: no heat
See if a fuse is blown, if not, you're looking at replacing a blower motor most likely. You can yank it and try getting it to run by connecting it directly to a power source, I'd assume. I've never messed with one personally. Done a couple heater cores before though.
Old Jul 24, 2007 | 11:42 AM
bigbill23's Avatar
bigbill23 is an unknown quantity at this point
Default RE: no heat
if the motor itself isnt working i would try the fuse and resisitor first, those are the most common, if they are good then i would hook a good ground and power to the motor to see if it works and go from there!
Old Jul 25, 2007 | 05:40 PM
Maldo15d's Avatar
Maldo15d is an unknown quantity at this point
Default RE: no heat
well, i have a 2001 , and the blower works but the heat does'nt... what should i do?
Old Jul 25, 2007 | 10:24 PM
bigbill23's Avatar
Default RE: no heat
if the blower works but u get no heat i would try flushing out the heater core! Those two hoses connected to the heater core at the firewall like to deteriorate from the inside out and clog the heater core. I saw that a lot at the dealership! Replace those two hoses(pretty cheap) and flush the heater core out and you should be good to go!!!
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
