no heat
Old Sep 5, 2007 | 09:16 AM
andomwoodard1977's Avatar
andomwoodard1977 is an unknown quantity at this point
Default no heat
I just replaced my heat core, but I'm still not getting any heat. I check the coolant and hose level and had the coolant replace about 3 months ago. The core is not plugged and the coolant is circulating properly.
Old Sep 5, 2007 | 09:21 AM
rriddle3's Avatar
Default RE: no heat
What does your temperature gauge show for operating tempereature? The thermostat may have failed in the open position.
Old Sep 5, 2007 | 12:02 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default RE: no heat
^^^i agree....are you getting cold air, warm air or what? Do you hear a swishing sound near the heatercore?
Old Sep 5, 2007 | 06:37 PM
Default RE: no heat
I just replaced the thermostat and its in the proper range.
Old Dec 10, 2007 | 09:32 AM
bmea's Avatar
bmea is an unknown quantity at this point
Default RE: no heat
how much did it cost to have the thermostat replaced?
Old Dec 10, 2007 | 10:15 AM
01BlazerLT's Avatar
01BlazerLT is an unknown quantity at this point
Default RE: no heat
what os this swishing sound, I am on my 2nd Blazer and both of them have made this sound, generally within the first 5 minutes or so after the truck has been started.
Old Dec 10, 2007 | 11:43 AM
junkmonkey's Avatar
junkmonkey is an unknown quantity at this point
Default RE: no heat
A water sloshing sound in the Blazer is probably trapped air in the system. Park the Blazer with the front higher than the back. With engine running, radiator cap open and vehicle up to operating temp, slowly fill radiator to capacity. This should drive out any trapped air in the system. Occasionally rev engine to force water to circulate through the block and back to the radiator, then when FULL, park on level ground and fill radiator to capacity if it's not up to the top. Sloshing sound should go away. If the radiator level drops after a few days or the sloshing sound returns, you may have a leak somewhere (either internal = intake manifold gaskets, or externel = sometimes very hard to see some leak prone areas, again intake manifold gaskets would be the culprit).
Old Dec 10, 2007 | 12:06 PM
felonyblazer96's Avatar
felonyblazer96 is an unknown quantity at this point
Default RE: no heat
my heat is tempermental...when it wont work i turn the **** on,pop the hood and punch the condensor and it turns right on
[/align]
Old Dec 12, 2007 | 07:28 AM
junkmonkey's Avatar
Default RE: no heat
I'm sorry, when you say "punch the condensor", I don't understand what you mean. The condensor is in the front of the vehicle (assuming you have AC), in front of the radiator. How can you "punch" it?
If you meant that big black box on the passenger side of the engine compartment, the blower motor is in there and you could have a bad connection to the motor.
The other thing to consider, although it doesn't sound likely in your case, is a vacuum problem to the heater control switch.
I'd focus on the blower motor connection first (if that is what you "punch" to get it to work). Good Luck.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
