No Heat
Old Apr 16, 2009 | 11:05 AM
jorge1's Avatar
jorge1 is on a distinguished road
Default No Heat
Hi there i own 98 blazer 4x4 as i let it heat up to operating temp and turn the heater on i will get heat for about 1min then it will just be no heat at all it blows air but not hot the Ac works just fine i checked the two heater core hoses thay both get hot, iv read many treads here but so many directions so am puzzeld. Would the stat be bad for one? two wich hose of the core to do a reveres flush and if anyone haves any ideas to relove this Thank you
Old Apr 16, 2009 | 12:54 PM
rriddle3's Avatar
1. Check your coolant level.
2. Is there an anti-freeze smell noticable from inside the cabin?
3. Is there any leak onto the passenger side floorboard?
4. Has the coolant system been drained and flushed recently?
Old Apr 16, 2009 | 10:06 PM
jorge1's Avatar
I check the leval its ok and its clean theres alread a t on one of the heater core line both lines get hot. To me its odd i check and normaly on other cars i owned while on i could see the colant circelating but i dont see that on this
Old Apr 17, 2009 | 07:59 AM
jorge1's Avatar
O if it would help i am getting unusual noises when hiting bumps on the right side of the dash i check the top and in back of the glove box and dont feel nothing lose i was going to check the air bag to see if it was lose.
Old Apr 17, 2009 | 11:55 AM
When you flush the core, alternate flushing through each hose. This is the proper way to flush the core regardless of the actual flow path of the coolant during operation.
Concerning your noise, it is possible that the hood hinge bolt is the cause. Wad up a rag in the back corner of the hood that is suspect and hit some bumps. Be careful not to bend the hood hinge with too much rag.
Old Apr 18, 2009 | 02:14 PM
jorge1's Avatar
Well i checked the hood and put some rags there but thats not it, am thinking it could be my shock on the right side but would that sound like if its from the inside? i would like to check the air bag to see if its lose couse once in a while the air bag light comes on. (going to do the flush this week ill keep you posted if it worked Thanks)
Old Apr 19, 2009 | 07:03 PM
Are the shocks original or after market? I installed new shocks into my old 2000 Bravada and the upper bushings were not the same width as the originals. I had to tighten the snot out of the upper shock mounting bolt to quiet them down. Sounded exactly like a bad ball joint.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
