no heat?
Old Dec 7, 2009 | 12:08 PM
blazzer99's Avatar
blazzer99 is on a distinguished road
Default no heat?
hi guys, and sorry i didn't know where to put this post!! but i have a problem, i dont have heat, when i turn the *** to hot i get olny cold air, a guy told me that i have to flush the radiator and when i tooked the guy said that the antifreeze was fine, my radiator is one year old, with that new gasket, and new termometor, is getting colder here in p.a so any suggestions?
thanks
blazzer 99
ps> happy holidays!
Old Dec 7, 2009 | 12:14 PM
Sisk's Avatar
Your heater core is probably plugged. You need to do a rad/coolant flush as the first guy suggested. It should clear any blockage that might be in the system. I'm not sure why the other guy told you it was fine...there is no way to see the heater core from looking at the rad. He is right though, your rad is probably fine. It's your core that's plugged.
If it still doesn't work after the flush you may have to replace your heater core. Start with a system flush though.
Old Dec 7, 2009 | 12:29 PM
blazzer99's Avatar
thank u for answer, the guy that told me the my radiator was fine, and didn't need to flushed it, was the guy who supost to do the flush, hi said the the *** was the bad pice, and i though ok maybe his rigth, thats why im doing research, so i dont spend to much cash, but i will do the flush first! thank u again.
Old Dec 7, 2009 | 12:34 PM
Sisk's Avatar
Your rad probably is fine as I said. But you can't tell if your system is plugged just by looking at the radiator. The flush clears the entire cooling system and gets rid of any blockages or gunk inside. A flush should only cost around 60$ if you get it done in a shop (might not include the price of coolant).
BTW - Try and take the time to type out your post right. It's very hard to read with the constant spelling mistakes and lack of punctuation lol.
Let us know how the flush goes and whether or not that fixes your problem
Old Dec 7, 2009 | 12:36 PM
*Moved to 2nd Gen Tech*
Once the truck is up to full operating temperature, feel the heater core hoses. If they are both the same temperature (relatively), then your core is likely flowing coolant properly. There is still the possibility of a restriction, but that is a good indicator. If one is cool and the other is warm, then you likely have a restricted core.
Old Dec 7, 2009 | 12:37 PM
blazzer99's Avatar
something alse? my heating was working last year! and when the mecanic replaced the thermostat,the gasket, and the radiator, after that i didn't have heat any more, so the question is, do u guys thing the he had something to do with it? or just is plugged because is old?
Old Dec 7, 2009 | 02:52 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
Check your spelling guy.
Mine takes longer to get to operating temp since I did a flush so I won't get heat for ten minutes or so now.
Did he put in a factory thermostat or a lower temp one? I know when I put a 180*F in my car I didn't get as warm of heat and the 160*F don't give out any heat.
Old Dec 7, 2009 | 09:37 PM
Buck731's Avatar
Buck731 is on a distinguished road
It sounds to me like the mechanic that changed the thermostat and radiator, must not have flushed the dexcool out of the heater core and put regular coolant in pace of dexcool and possible gelled up the heater core. Back flush the core with a garden hose with low pressure (High Pressure with blow the pipes in the core...found out the hard way) a few times or have a shop do it. It should work...If not, you'll need a new heater core.
Old Dec 20, 2009 | 11:39 AM
cferris2103's Avatar
cferris2103 is on a distinguished road
I have the same problem... Its freezing in CT with 12 inches of snow and i have no heat. I flushed out the heater core and replaced the thermostat and gasket. Still no heat. My only other idea is the blend door actuator. I saw in the forums a step by step to check and replace it if necessary without taking the entire dash apart. I will try to find it and post it but thats my last resort before I start replacing heater cores.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
