No heat
Old Jan 24, 2010 | 08:30 AM
thecartin69's Avatar
thecartin69 is on a distinguished road
Default No heat
I changed the thermostat, and the heater core is not leaking just not getting hot.. really starting to get to me. some1 looked at it and told me it was the "glen door" or something like that.. please some one e-mail me some options, or soultions. thanks
chris
Old Jan 24, 2010 | 02:26 PM
Sisk's Avatar
they were probably referring to your "blend door". Do a quick search on the forum for more info.
Old Jan 24, 2010 | 02:33 PM
SHA-BOOM280's Avatar
SHA-BOOM280 is on a distinguished road
have you tried to bleed the coolant system i have had the problem before and that did the trick
Old Jan 24, 2010 | 03:11 PM
wireman's Avatar
wireman is on a distinguished road
had the same issue on my '02 4x4 blazer, I took the hoses loose (heater core) that goes into the water pump and motor and basically flushed water through the heater core and its been blowing hot every since.
Old Jan 24, 2010 | 09:20 PM
PINK JUNK's Avatar
PINK JUNK is on a distinguished road
CLR flushed through the heater core then rinse will do the trick!
Old Jan 25, 2010 | 07:57 AM
terry s's Avatar
terry s is on a distinguished road
You need to decide what is wrong before you waste any time trying to fix something that does not need fixing.
With the engine at normal operating temp. both heater hoses should be hot to the touch. If so you may have a blend door problem.
If one is warm or hot and the other one is much cooler the heater core is restricted.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
