No Heat
Old Oct 31, 2011 | 09:44 AM
Tomar1226's Avatar
Tomar1226 is on a distinguished road
Default No Heat
So I have Just cold air blowing through my vents. I understand this would be and issue with the heater core and the hoses needing to be cleaned out. Could a faulty Thermostat also cause the heat not to work? Just curious
Thanks for the help
T
Old Oct 31, 2011 | 02:34 PM
dobyken's Avatar
dobyken is on a distinguished road
Do a quick search here for flush heater and you should be able to find the procedure..pretty easy. The thermostat has almost zero to do with the heat unless it's stuck fully open in a very cold climate. The two main causes of no heat are clogged core and the blend door which allows the cabin air to go through the heater core. If both your heater hoses on the firewall are hot then you most likely have a blend door problem. If one or both are cool then your core is plugged. Also there is no water valve that controls flow to the heater core....water circulates all the time.
Old Oct 31, 2011 | 04:42 PM
Tomar1226's Avatar
Thanks for the info I will look into that. I have read up on heater flushing just seems like a pain. I guess it will be easier and cheaper than doing the thermostat thought. I will take a look at that and see what I find.
Thanks for the help
T
Old Oct 31, 2011 | 06:35 PM
MrRedBlaze04's Avatar
MrRedBlaze04 is on a distinguished road
i had the same problem. I flushed my heater core and had heat blowing right after i did it.
Old Nov 2, 2011 | 09:40 AM
uglyvw's Avatar
uglyvw is on a distinguished road
Also first make sure it is full of coolant and any air is burped out.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
