No heat
Old Mar 14, 2007 | 05:00 PM
air8grr's Avatar
air8grr is an unknown quantity at this point
Default No heat
2001 Blazer : I can not get any heat no matter where I set the dial. Thermostate has been changed. is the rotory dial mechanical or electric. [:-]
Old Mar 14, 2007 | 09:57 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Default RE: No heat
Have you tried flushing the heater core? If not I would try that.
Old Mar 15, 2007 | 02:47 PM
vagnozzi's Avatar
vagnozzi is an unknown quantity at this point
Default RE: No heat
flush flush flush...xInfinity...does wonders
Old Mar 16, 2007 | 10:37 PM
SlimshagE's Avatar
SlimshagE is an unknown quantity at this point
Default RE: No heat
I just had the same problem with my blazer. I flushed, changed thermostats and was even fixing to swap out the heater panel. Something told me to check all individual fuses. I checked each one and sure enough I had a fuse blowed that didnt even say heater on it but it shared the same circuit. I replaced the fuse and ever since, you can fry chicken in that bad boy. It will be the fuse box to the left side of your dash. Hope it helps.
Old Mar 17, 2007 | 12:08 AM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: No heat
Yes you probably need to back-flush the heater core. If you don't know what that means do a search on this forum, I'm sure you'll find it. And to answer your question the Temp valve (door as most people call it) is electric, just the temperature tough, the rest are vacuum controlled.
CSCustomCars
Nov 22, 2010 08:24 PM
Lodi Dodi
Nov 12, 2010 06:26 PM
mcaanda
Dec 15, 2009 08:31 PM
jorge1
Oct 9, 2009 12:17 PM
Stopphn
Headers, Intake, & Exhaust
Jun 1, 2008 07:24 PM
