NO HEAT - need help!!!
do you have a temp gauge in the truck? is it getting to operating temperature? i would try flushing the heatercore. its possible that half or more of it is clogged and the hot water is just flowing through the open ports causing it to never have heat.
last time i had this happen it was because the thermostat was stuck open. did you change it yourself? wonder if its possible its just a bad thermostat or if you brought it somewhere they didnt put it in
This saga might be continued!!
Thanks again abig84
thanks Maxboost25psi!!
just wanted say thanks for all suggestions!!
It sure is great to have this support from all you smart fellas.
Complete flush & brand new GM thermostat seems to be the answer for now!!
thanks again!!
:icon_ razz:
thanks again!!
AWESOME....I am a Noob here on this forum, but have been on Supraforums, 3si.org and others for years....
These forums are really great...reg dudes and gals helping each other out...gives ya a good feeling knowing you can reach out and ask for help when needed.....
CONGRATS on the new found heat!
My '00 Jimmy is having a heat issue as well. Regular heat doesn't work so I have to use circulation mode to get any heat. It works great on that mode but it switches off automatically after 5 minutes so I have to keep pressing it which is getting annoying. My mechanic thinks the heater core is blocked, he said that the s-10 series had problems regarding this issue.
Update: I just came back from the mechanic and they found that my heater core was indeed completely clogged up. They did a reverse flush and now I have heat again!
Apparently mine was filled with this stuff & I've been told it's known to clog cores cause it turns to sludge after a while. I did have mine flushed & I do have HEAT!! But he re-filled with Dex cool again cause this is what GM says my '98 should use. But I was warned to change it before 100,000 km. or I'll have more issues again. Nice thought eh!! NO HEAT AGAIN!!
Regardless, glad to hear you have heat also. Gotta keep those toe-toes & fingers warm !!
Yes the Dex-Cool was indeed the culprit. I noticed some orange granules in the coolant tank a few months back but figured it was alright since the mechanic had just topped it up for the winter. Well fast forward to present day, it had produced an orange sludge which caused the failure in the heater core; the sludge was even present around the radiator cap too.
I have a 1998 GMC Jimmy and the heater has stopped working. Both heater hoses however are hot and the windshield does not steam up nor is there any leakage on the passenger side flooring, which from what I understand both are large signs of something wrong with the heater core. So I doubt it is the heater core that has a problem. The engine has plenty of coolant in it, so it isn't a shortage there. I also doubt it is a stuck thermostat, because the engine is not overheating at all. Could it be an electrical issue? Like a blown fuse or something? And how would I go about figuring out which fuse if so?
