No Heat. Where's the Heater Control Valve ??
Old Aug 25, 2009 | 12:14 AM
Katmandu's Avatar
Katmandu is on a distinguished road
Exclamation No Heat. Where's the Heater Control Valve ??
Starting to get nippy here in the AMs and found out the heater is not working in my 99 Blazer.
The AC (and vents) all work great.
I was looking under the hood (around the heater hoses) for the heater control valve and can't find it! There is nothing on the hoses from the intake to the firewall.
Where is the heater control valve located ? (Didn't find it in the Search either).
Old Aug 25, 2009 | 12:33 AM
You won't find one. There is no such device which would control the flow of coolant through the heater core. There is the temperature door actuator that is in the duct work which controls the flow of air over the heater core inside the HVAC housing. There is a gear inside which can snap causing the door to be stuck in a particular position.
Old Aug 25, 2009 | 12:53 AM
Katmandu's Avatar
Question
So there's constant flow through the heater core then ?
The AC (and ducts) seem to work fine.
Is this just an issue with the temperature door actuator then ??
Also, my truck only runs around 180 degrees. Would a 195 thermostat help ?
bigjayfromwa
18
Feb 15, 2013 01:47 PM
89Recon
Oct 22, 2011 05:50 PM
IndianaBlazerGirl
Sep 6, 2011 06:22 PM
bigdaddykane93
Dec 16, 2010 04:28 PM
waviaerith
May 22, 2010 10:02 PM
