No Oil Pressure Help
Old Jul 29, 2009 | 05:38 PM
dew88's Avatar
dew88 is an unknown quantity at this point
Default No Oil Pressure Help
How can I check the oil sending unit, or check that the oil pump is working? I just did a motor swap and the oil pressure is showing 0. There is oil moving through the external filter (I removed the line to see and its moving) does this mean the pump is working?
I am scared to run it with the gauge not working, I want to ensure the oil is pumping so I don't blow the motor. Thanks
Old Jul 29, 2009 | 07:14 PM
The best way is to remove the oil pressure sending unit from the back of the block and attach a manual pressure gauge to the port. Flow does not always mean pressure.
LWegner
May 8, 2011 08:25 AM
Spectreblazer
Mar 15, 2010 11:16 PM
davidsv8mustang
Feb 18, 2010 02:29 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
