no power... need help!!!
my 2000 chevy blazer stock has no power. for instance i would try to back over a curb and give it some gas and it would start to lose power and jump from about 1000 to 1500 rpms. i have no idea what is wrong with it and would appreciate any help or ideas given. thanks for the responces in advance.
Does the engine run fine at idle? Will it rev-up nice and smooth?
How many miles on the engine? Usually loss of power is due to a plugged-up cat. Easy test is to remove the pre-cat O2 sensor, put some type of deflector/heat shield if possible, then do a quick to see if power has returned. This will set the Service Engine Soon lite and will need to be cleared. If power does not return, then it is not the cat and time to look at fuel and spark.
Let us know what you find out.
chrisjanicki01
11-14-2009 05:45 PM
randallsblazen
03-09-2009 10:45 PM
IROCZ
02-04-2009 09:53 AM
