need help connecting power wire from battery to into the car
Old Mar 1, 2009 | 03:42 PM
randallsblazen's Avatar
randallsblazen is an unknown quantity at this point
Default need help connecting power wire from battery to into the car
hey i neeed helppp...i just bought a 95 blazer and i put in all new speakers ..i bought two 12" alpine type S and i just cant find where to run the wire from the battery through my car to my amp.... can someone please helppp!!!!!!!
Old Mar 1, 2009 | 06:05 PM
Default RE: need help connecting power wire from battery to into the car
The easiest location (which has been covered quite well in past threads) is to run the wire through the grommet that the antenna wire uses. It is located to the left of the transmission tunnel on the passenger side. You can locate it by looking up under the dash. You may have to remove a trim panel and/or pull back the carpet/sound-deadener.
Old Mar 9, 2009 | 03:47 PM
my's Avatar
my
my is an unknown quantity at this point
i could not run my amp wire throught their so i had to drill a new hole i did it up nex to the iner fender but when you do it just be carfull to not hit wirers or somthing stupid like that
Old Mar 9, 2009 | 05:12 PM
onecrazyfoo4u's Avatar
onecrazyfoo4u is an unknown quantity at this point
Why could you not fit it? How big of wire run was it? Just curious....
Old Mar 9, 2009 | 10:45 PM
Hotfingers's Avatar
Hotfingers is an unknown quantity at this point
Default It worked for me.
I just ran a 4 and an 8 gauge through mine this afternoon. I just gave the rubber grommet a little slice with a razor and put the 8 gauge through enough until I could reach it in the engine compartment. Then I taped the 4 gauge on to the 8 and pulled them both through together.
joshn444
May 7, 2013 06:58 AM
Newblzrowner
Mar 25, 2012 03:16 PM
JRob238
Mar 20, 2011 04:46 PM
denver jimmy
Oct 4, 2010 12:56 AM
knightryderx2
Feb 21, 2010 05:58 PM
