No Spark, no signal at ecu
ok I have a 97 blazer 4x4
It does not get any spark, I followed a troubleshooting flow chart and it took me back to the ecu. It said look at IC circit on the vcm C3 connector. I believe this is pin 9 on the connector, I tested it and it was not getting any signal from the ecu.
Went to the yard today and got an ecu that I know works as it came off a running motor but the test still says its a bad ecu. anyone got any ideas?
I have replaced the Crank sensor, distributor cap, wires, plugs coil and ic module but still nothing. and I have followed the flow chart to check for grounds etc.
any help would be awesome
awesome thanks for the schem, I will check some things this one looks different than the one I was looking at. I did do a resistance test through the wire to make sure there was no break in it between the PCM and ICM but i will be back checking grounds tonight.
well I got it running, I pulled the new CKS I put in and put the old one back in. no go. So I changed out my stock ecu for a junkyard one and vroom. started right up. Then I pulled the old CKS and put the new one back in. Started again no problem. SO I drove it to work last night it worked ok but stumbled a bit. I fifured it needed a cks variation learn. Got home parked it and was gonna go and get it done today. when I went to start it today I got nothing again.
It was snowing last night so theres alot of moisture everwhere so that may have a contributing factor but I would think it would have quit on me when I was driving if water was a problem.
Any help is awesome thanks
pierrem
14
Dec 12, 2009 08:03 PM
88blackzcand95blazer
Engine & Internal
14
Jan 24, 2009 07:15 PM
lunari
Jan 4, 2009 07:50 PM
