no start again! grrr
Old Feb 2, 2014 | 02:25 PM
flypaper's Avatar
flypaper is on a distinguished road
Default no start again! grrr
95 jimmy with cmfi
truck started to misfire,lost power,finally it stalled,dead on side of road.
towed home
has spark,will fire on fluid
checked fuel pressure 50 lbs
changed out china delco pump
got a delco pump from brazil this time.
now has 60 lbs and passes 10 min test
still no start
popped off the intake,has power at connector with test light
before i take the plunge
is it safe to say it is the spider causing my no start condition?
any other checks to do?
i don't like to throw parts at it
thanks in advance for any help
Old Feb 2, 2014 | 10:27 PM
canuck blazer's Avatar
canuck blazer is on a distinguished road
could also be your cap and rotor, or crank shaft sensor ,cam shaft sensor,
are there any codes that came up?
Old Feb 3, 2014 | 10:46 AM
flypaper's Avatar
i was thinking since it will fire on starting fluid
would point towards a fuel delivery problem and not the ignition?
Old Feb 3, 2014 | 01:26 PM
just went through this with my 2002 chevy blazer mine it was the cap and rotor threw the timing off
maybe a leak at the plenum
Old Feb 3, 2014 | 01:34 PM
cferry7's Avatar
cferry7 is on a distinguished road
Default Fuel Injectors
Do you know whether the Fuel Injectors of the Spider are injecting fuel ?
Yes you can check the electrical connection of the ( Fuel Injectors )Spider Unit by placing a 12 v LED on the electrical connections and you should see the LED pulse when trying to crank the engine.
IF you lift one of the injectors and place a paper towel under the injector,
this should tell you if the injector(s) are squirting fuel while cranking the engine.
Old Feb 3, 2014 | 03:03 PM
flypaper's Avatar
nope,
i did not check that...thanks for the help
that is why i posted this
i will do it before i replace anything.
the cap and rotor were replaced a couple of months ago and
they looked ok with no visible defects when i looked at them.
it was the first thing i looked at.
Eff10
22
Dec 8, 2009 07:21 PM
portcqb
Jul 21, 2008 10:35 PM
dmc919
Dec 30, 2007 10:14 PM
ripoffblazer
Jun 12, 2007 09:10 AM
Zasder
Apr 21, 2007 07:17 PM
