Trouble installing new vac switch
Old Feb 3, 2014 | 02:40 PM
Cam1975's Avatar
Cam1975 is on a distinguished road
Default Trouble installing new vac switch
Title says what my problem is. I had a bitch of a time getting the old one out, and now I'm having trouble threading the new one in. Is there a trick to it?
Old Feb 3, 2014 | 03:01 PM
rockp2's Avatar
I can't think of anything unique about installing it off the top of my head. The transfer case was in 2wd when you removed it, yes? The only thing I could think of is if it was in 4HI when you removed it the shift fork will be in the "up" position which would push on the spring loaded ball end of the vac switch. But I don't know if it would be high enough to prevent any threading without downward pressure.
Old Feb 3, 2014 | 03:21 PM
Cam1975's Avatar
No...it was me freezing fumbling fingers that were the problem. 3 hours of shoveling snow before I decided to take care of it. After having a bitch of a time removing the old one I was trying to screw it I to a depression in the top of the case and not the actual threads Needless to say I couldn't see what I was doing and my fingers were effectively just as blind. After I posted I took the time to warm my hands up a bit and was done in a couple of minutes once I climbed back underneath.
newguy
Jan 10, 2015 03:34 PM
JMC
Mar 5, 2013 08:47 AM
ccpanel
Dec 20, 2012 08:03 PM
Budd
Sep 11, 2011 07:41 AM
WhiteTie BlackJacket
Feb 13, 2008 03:22 PM
