No Start No Crank??????
Old Dec 23, 2011 | 11:38 AM
mattison67's Avatar
mattison67 is on a distinguished road
Default No Start No Crank??????
2001 4X4 Blazer
This problem just started. When you turn the key to the start position nothing. No clicks or anything. In the on posistion all the interior lights, headlights, radio, etc.... work fine proceed to turn to start position all goes out and nothing untill you go back to on position. If I keep trying after a while it will fire right up and run fine? Also in the on position the volt meter reads like 9-11 volts?
I'm very mechanically inclined so any help would be great. Also in the summer I printed out someones step by step pictures on replaceing the intake gaskets. Went great. Thanks for that one and my horn issue.... fixed.
Old Dec 23, 2011 | 12:26 PM
pettyfog's Avatar
check the two big cables from battery.. probably the pos battery term, since lights work till you try to crank it.
Old Dec 23, 2011 | 01:13 PM
mattison67's Avatar
I'll give that a try. Probably tomorrow though. I worked all day yesterday, went in last night for a project till 2am, then worked today. Sleepy time for Matt.
Old Dec 24, 2011 | 01:21 PM
mattison67's Avatar
So of course it won't act up now. The battery cables were slightly loose. Maybe 3/4 of a turn on each. Started it 50+ times. Let it run and get good and warmed up and still starts and runs like a new car. I'll keep ya posted.
Old Jan 10, 2012 | 03:37 PM
mattison67's Avatar
So it erred everyday up until today. Same thing. Takes about 20 tries before it will finally turn over and it starts right up? Where do I go from here?
Old Jan 10, 2012 | 04:58 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
New Battery , your battery may have froze , or could be just a default in the battery . If you have a good battery charger with engine start put it on it and it should start right up . My brothern laws truck did the same thing yesterday .
Old Jan 10, 2012 | 06:35 PM
Esty's Avatar
Esty is on a distinguished road
I would start with testing the Battery make sure all the conections are clean and tight at the battery the starter all the grounds
Now check your Neutral Safety Switch, Starter Relays, Ignition Relay(There are not the same), Ignition Starter Switch
Old Apr 23, 2012 | 02:33 PM
mattison67's Avatar
Been a while since I figured it out. Sorry I haven't posted an update. It ended up being the starter. Fun job that was.
Buddykitchen
Dec 10, 2016 06:37 PM
Travis West
Dec 31, 2012 12:54 PM
g_mike
Aug 22, 2010 02:46 PM
copper_eyes
13
Feb 26, 2008 12:22 PM
huskerinaz
13
Dec 8, 2007 03:14 AM
