No start! Timing Advanced EDI
Old Jan 16, 2011 | 02:58 PM
luca1587's Avatar
luca1587 is on a distinguished road
Default No start! Timing Advanced EDI
95 Jimmy cpi 262w! Horizontal Distributor! I can only get my Distributor fully seated within a few degrees before or after the 6! The gears will only mesh in these two position?
Would the engine be able to start with the rotor in this position?
Attached Thumbnails No start! Timing Advanced EDI-t1.jpg   No start! Timing Advanced EDI-t2.jpg   No start! Timing Advanced EDI-t3.jpg
Old Jan 16, 2011 | 03:39 PM
Kaput's Avatar
Kaput is on a distinguished road
Are you getting spark from coil to the distributor and from the distributor to the plugs?
Old Jan 16, 2011 | 04:28 PM
luca1587's Avatar
I wasn't at first, now im gettin one but it still wont turn over! could the distributor be bent?
Old Jan 16, 2011 | 04:48 PM
Kaput's Avatar
To us down here in the south, turning over is trying to start. Is it trying to start (turning over) or are you getting nothing?
Old Jan 16, 2011 | 05:57 PM
luca1587's Avatar
it will crank but not start
update: got the timing right but still wont start! any help would be great!!
Old Jan 20, 2011 | 08:41 AM
luca1587's Avatar
SOLUTION: How it happened i don't know, but after I did the head gaskets some how I rotated the engine and when I reset to tdc I was 180* off on the rotor. Witch means i was in exhaust stroke not compression stroke!
TIP: Also the search through this site doesn't always pull up all the forums with the info you searched for. But for whatever reason if you search through google, hit the link that says "MORE RESULTS FROM BLAZER.COM" and you get alot more results!
jcpc83
Mar 8, 2011 02:18 AM
87fullsizeblazer888
Feb 26, 2011 02:31 AM
dfowler03
Aug 29, 2010 02:43 PM
Hanr3
Oct 25, 2009 10:52 PM
