No starter crank help please
Old Dec 13, 2016 | 05:19 PM
Slim6969's Avatar
Slim6969 is on a distinguished road
Default No starter crank help please
Hey guys. I have a 2000 blazer 4.3 4door 4x4 I went to start it and nothing happened I could here the relay click and that's it checked batt volts have lots replaced relay. Still nothing. I can make the starter turn by jumping it but it just spins does not engage. When I turn the key it does not even spin any ideas
Old Dec 13, 2016 | 06:30 PM
rockp2's Avatar
Even though you show voltage, the battery could still be bad under load. Or, you could have corrosion in your battery cable(s). An auto parts store can do a load test on your battery. Once you have confirmed your battery is good, do a starter voltage drop test (google a video on this by Dan Sullivan).
Old Dec 14, 2016 | 04:48 PM
Slim6969's Avatar
So just an update. I used a test light to check power at the starter. There was. I then checked the signal wire had a buddy turn the key to start and there was power there to so that means everything befor the starter is good and working the way it should change the starter and started my truck no problem. Thanks for the for the help.
Buddykitchen
Dec 10, 2016 06:37 PM
dj00140
May 20, 2013 06:37 PM
g_mike
Aug 22, 2010 02:46 PM
515Blazer
Feb 10, 2010 06:23 PM
aleks77
Nov 11, 2009 06:46 PM
